Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Twin Disk Wideglide for 98 LowRider
Old 07-10-2011, 01:12 AM
locustar's Avatar
locustar
locustar is offline
6th Gear
Default Twin Disk Wideglide for 98 LowRider
I have a 98 lowrider. Stock narrow glide, 18" front wheel. I want to go to a wide glide front end with the 16" front wheel. I am hoping to keep my twin disks up front. Alot of the wide glide kits claim they are set up for single disk only. I want to keep the look of stock rake and stretch. Any suggestions?
Old 07-12-2011, 06:02 PM
mtnlvr's Avatar
mtnlvr
mtnlvr is offline
Not a lot of activity on front ends in this section huh?
If you look around at aftermarket front ends you should find some that are set up for dual disk. Otherwise, find yourself a set of trees and order the appropriate length forks separately setup for duals.
I plan on putting a front end from motorcyclemetal.com on my 98 Wide Glide this winter (if things go the way I plan). Howard offers dual disk as a standard.
Keep in mind that your rim will not work as is with a wide glide front end. The hubs will have to be spaced out to push the rotors out in order to put them in the right spot for the calipers....or custom hubs....or rim. I'm not sure what I'm going to do there yet. I'd love to find a wider tire for my Dyna, but if not, I'll just machine up a new hub.
Hock Luger
06-20-2015 12:40 PM
RSDUDA
Shovelhead
08-07-2014 05:27 AM
locustar
07-09-2011 06:55 PM
JoeBlowme
Shovelhead
02-26-2008 06:21 AM
deeblues
10-02-2007 08:34 AM
Quick Reply: Twin Disk Wideglide for 98 LowRider
