Gasoline + paint = ARGH!!!!!
A little over a week ago, I replaced the dead fuel gauge sender in Reaper's gas tank. After installing the new one, I took her for a good long ride (close to 100 miles), filled her up, came home and checked her over for leaks. Everything seemed to be fine. All last week, I didn't have the opportunity to ride, and I was out of town on the weekend, so she sat that whole time with the full tank of gas.
I have been planning to spend a lot of time in the saddle this week, as the weather is finally supposed to be getting nice for a stretch. Last night after getting home from work, I went to look her over, and saw this :
So I pulled her console and tank bag up and found this :
Turns out the brand new gasket I bought from my local HD dealer had swollen (you can see it in the pic below), and gas leaked out for a week, really screwing up the paint...
In case anyone is wondering. I have the service manual, I bought new screws (they're one use only), and I torqued everything to spec. This ain't my first rodeo.
After removing the screwed up paint, and cleaning the affected area, the tank looks like this. Not nearly as bad, but the paint is screwed hard. The gas ate through the clear-coat, and at least a couple of layers of black.
The only slight silver lining is that the Reaper graphic didn't get damaged. Only the background black paint. So, now I have to get that fixed, which means pulling the tank and taking everything off, etc... but it should be repairable.
Needless to say, I am NOT a happy Clam. I am also very concerned that the new gasket I get will do the same thing. Whatever material they used for the one I installed didn't stand up to being exposed to gasoline, and since it seals the top of the gas tank...
Cheers!
Well, I'd try to get some kind of sealer on it the next time it's painted.
As for affording to have it done, I really can't but the way bike are now compared to when I used to do my own work in the 70s, they're way to complicated for me. So it not a choice but a necessity.
Cheers!
Received 2,073 Likes
From what you said,it wasn't leaking after you finished job and checked it.Something softened that gasket up and it should be OK with gasoline.Wondering if Canada has ethanol in their gas like we have in the States.Over 10% of ethanol will cause problems with seals and gaskets which were not designed for use with it.
Corn gas is SUCH a scam... it's bad for engines, it's less efficient, and causes more pollution to produce. Not to mention it uses up valuable farm land to grow the crappy corn to make this crap. Pure BS.
