Air temp sensor location
Old 11-21-2016, 10:48 AM
Rees107's Avatar
Rees107
Rees107 is offline
Default Air temp sensor location
Hey guys and gals, I need some help. I just installed a oil temp gauge in place of the air temp. But I cannot find the air temp sensor, any ideas. I have a 2009 ultra classic.
Thanks for any help.
Old 11-21-2016, 10:57 AM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 14,640 Likes on 4,631 Posts
its under the front faring, follow the wire its usually near the top off to the side of the radio
I'd just cut the wire, or just leave it under there, unless you were planning on using it ever again, Which I know of nobody who has ever done that
MARKUS702 (07-02-2022)
Old 11-21-2016, 12:15 PM
Ezridr60's Avatar
Ezridr60
Ezridr60 is offline
This is an '07 FLHTCU. I think they changed location, not sure of year, to get it out from under the batwing to get more reliable readings. It's just next to the fuel gauge
Old 11-21-2016, 12:21 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
Mine is on the left side of the neck below the fairing.
Rees107 (11-21-2016)
Old 11-21-2016, 12:51 PM
gusotto's Avatar
gusotto
gusotto is offline
I just let mine dangle.
Didn't want to have to insulate a bare wire.
Old 11-21-2016, 02:21 PM
Bubba Zanetti's Avatar
Bubba Zanetti
Bubba Zanetti is offline
Received 13,190 Likes on 5,617 Posts
Are they still putting those useless gauges on the Glides? I had an 04 EGC and that POS guage was always about 20-30 degrees higher than the actual temperature.
Old 11-21-2016, 09:15 PM
Rees107's Avatar
Rees107
Rees107 is offline
Thanks for all of the help, found the little SOB. Its on the left side of the neck just below the wire harness.
Old 11-22-2016, 06:41 PM
Rees107's Avatar
Rees107
Rees107 is offline
This is where the air temp sensor is on my 2009 Ultra Classic, near the grease zerk on the neck. It's gone now just in case you are trying to find it.
Old 11-22-2016, 07:59 PM
Ezridr60's Avatar
Ezridr60
Ezridr60 is offline
This was a photo someone posted of a later model sensor location on another thread. i believe the sensor is right in the middle of the photo. Forgot I saved this.
Rees107 (11-22-2016)
Old 11-25-2016, 08:23 AM
Spartanden's Avatar
Spartanden
Spartanden is offline
Received 8,249 Likes on 6,009 Posts
Almost as worthless as the fuel gauge!!! I rarely look at mine.... it is 10-15° higher than ambient temp. Fuel gauge is for reference too....as far as I'm concerned. I still reset the odometer at each fill up and use that as my gauge. can never figure why they still install useless gauges.....
Quick Reply: Air temp sensor location
