proper piston ring break-in procedure
Old 03-26-2011, 05:23 AM
dog155's Avatar
dog155
dog155 is offline
This one like helmets,leathers,and all other things people are passionate about has many an opinion!Know for certain what has worked for me over the last 45 yrs no need to try anything different.Hastings reccommends it the way most of us do it.
Old 04-16-2011, 08:42 AM
Joker65's Avatar
Joker65
Joker65 is offline
Originally Posted by MNPGRider
A new bike engine has been "run in" at the factory, before released for sale. Seating rings, as per the article, is for "overhauls," and is what many gurus recommend. When installing new rings in a new overhaul, warm the bike up to operating temperature, roll on the throttle hard several times, and your new rings are seated. Baby it, and you'll use oil forever.
The only thing I would add, is let the engine cool down before re-torqueing and setting tappets, etc.
http://www.americanrider.com/output.cfm?id=1054261
Break-In The only parts of your new 95-inch Twin Cam engine that need break-in are the piston rings and the cylinder walls they run on. This can and should be done in a very short time and over a short distance; a few minutes and a few miles, in fact.
The precision of the Wiseco bore job, their pistons, and the rings are such that only small initial wear is required to properly seat the rings. The proven best way to accomplish this is to load the rings against the walls of the cylinders by accelerating at full throttle. Here is how you go about seating your new piston rings:
1) Do not start the engine until you are ready to ride the bike.
2) After starting, quickly get out on the road and into third gear.
3) Accelerate at full throttle from 30 to 60 mph in third gear.
4) Close the throttle and coast back to 30 mph.
5) Repeat this full throttle/coast procedure a total of 10 times.
6) The rings are now seated and you can ride normally.
Been there, done that.
Exactly!!
BobRR
07-13-2019 09:07 AM
guido4198
EVO
11
07-07-2019 03:35 AM
2mOOn
08-16-2014 11:00 AM
Schulte94
EVO
25
04-12-2014 07:30 AM
streeteagle
08-13-2008 04:13 PM
Quick Reply: proper piston ring break-in procedure
