proper piston ring break-in procedure
BREAK-IN PROCEDUREBack
STARTING PROCEDURE2. Start engine and set throttle to an engine speed of approximately 25 miles per hour (trucks, tractors and stationary engines one-third throttle) until the engine coolant reaches normal operating temperature. Then shut down engine and retorque cylinder head bolts, recheck carburetor adjustments, ignition timing and valve tappet clearance. (Run engine at fast idle during warm-up period to assure adequate initial lubrication for piston rings, pistons and cylinders.)
STARTING
http://www.mototuneusa.com/break_in_secrets.htm
I'm sure someone will be here shortly to say I'm nuts and you need to baby it for hundreds of miles.
Their quote "pistons do not die, they are KILLED"
First bike tear down for me...hell I didn't know!!
Did a geardrive / big bore project. Asked my machinist about break in proceedure....
Was told to start it up, bring it to 2.2k rpm and let it run for 20 minutes...just make sure ya got big box fans on it.
Yep...asked three differrent times over a week. Same explaination each time.
Figgured what the Hell...they do this for a living, and I've spent my cash with them...gotta go with their method. Followed those instructions to a "T."
When the owner of the shop found out what I'd done, he had concerns (to say the least)...seems I had received some missinformation. Got a personal call from him almost immediately.
Gotta say that she runs like a beast.(compared to stock) Got 1k on it in the last 2 weeks. Have a turner lined up to dial her in...gonna be about 2 weeks. He told me he'd check the integrity of the engine (comp check / leakdown test), to make sure of no issues.
All this just goes to show that these really are tough motors!!!
Just sayin'
Beav
Never any leaks, excellent cyl pressures and never uses any oil.
That's about it.
16K miles and no issues apparent.
this is like the synth/dino debate... ask 10 people that work on engines for a living and you will likely get 10 somewhat different answers.
