break-in oil for new engine build?
Old Aug 14, 2014 | 08:55 PM
2mOOn's Avatar
2mOOn
Default break-in oil for new engine build?
For those that have done a major engine upgrade, what oil did you use for the initial break-in period?
Thanks
Old Aug 14, 2014 | 08:58 PM
bigskyroadglide's Avatar
bigskyroadglide
Dino oil
You should change it very quickly doesn't pay to use syn
Old Aug 14, 2014 | 09:37 PM
dawg's Avatar
dawg
Dino. Change at 50 miles, 100 miles, 500 miles then 1000 to syn
Old Aug 14, 2014 | 09:39 PM
soft 02's Avatar
soft 02
Engine Break-In Procedure
Note: S&S engines are designed for high performance and as such are not as tolerant of inadequate break-in as stock or lower performance engines. Correct breakin will assure longer engine life and will prevent unnecessary engine damage. Engine damage caused by improper break-in is not covered under the S&S warranty.
A. Initial start up. Run engine approximately one minute at 1250-1750 rpm. DO NOT crack throttle or subject to any loads during this period as head gaskets are susceptible to failure at this time. During this time, check to see that oil pressure is normal, that oil is returning the oil tank, and that no leaks exist.
B. Shut off engine and thoroughly check for any leaks or other problems. Let engine cool to the touch.
C. After engine has cooled, start up again and allow the motor to build some heat. Engine should be run no longer than three to four minutes. When the cylinders become warm/ hot to the touch (approximately 150°) shut the motor down and let it cool to room temp. Follow the same cautions as for the initial start-up, and continue to watch for problems.
D. Repeat this procedure 3 or 4 times. Each successive time it should take slightly longer to warm up and you can increase the temp slightly each time (+10°). You can be more liberal each time with the rpm, gently vary rpm continuously from idle up to 2500 rpm in the final cycle. Don't be too concerned with final carb settings at this time because idle speed and mixture cannot be correctly set until the motor reaches full operating temperature. The motor should not reach that temperature during these cycles. Do not allow engine temperature to become excessive. After the motor has cooled to room temperature for the final time you are ready to start the 1000 mile engine break-in process.
E. The first 50 miles are most critical for new rings and piston break-in. Engine damage is most likely to occur during this period. Keep heat down by not exceeding 2500 rpm. Avoid lugging the motor, riding in hot weather or in traffic. Vary the engine speed. Do not lug the engine. We recommend changing the oil at 50 miles.
F. The next 500 miles should be spent running engine no faster than 3500 rpm or 60 mph. Avoid continuous steady speeds, and do not lug the engine. Vary engine rpm. We recommend changing the oil again at 500 miles.
CAUTION: Lugging or running engine prematurely at sustained high rpm may result in damage to pistons and other engine components. S&S voids it's guarantee if engine is not broken in properly.
G. For the balance of the first 1000 miles the motor can be run in a normal but conservative manner. You can be more liberal with the rpm range and motorcycle can be operated at normal highway speeds. Avoid overheating or putting any hard strain on the engine: no drag racing, dyno runs, excessive speed, trailer towing or sidecar operation.
H. After 1000 miles, verify carburetor jetting and adjustment. Change the engine oil. Motorcycle can now be operated normally.
I. Have Fun!
Old Aug 14, 2014 | 09:41 PM
2mOOn's Avatar
2mOOn
Thanks for the quick responses. However, I was hoping for suggestions on what brand? The owners manual suggests oil for diesel engines as an "excellent" dino oil....like Rotella. Would this work?
Old Aug 14, 2014 | 09:44 PM
soft 02's Avatar
soft 02
Dello 400. Is what I use for the 50 mile part then any MC 20w50 for the first 1000 then I use LiquiMoly 10w-60 synthoil racetech gt1 for the remainder of the time.
Old Aug 14, 2014 | 09:52 PM
dave grider's Avatar
dave grider
I used HD NON SYNTHETIC for first 3000 miles chg at 100/300/500 after heat syncing 3 times
Old Aug 14, 2014 | 11:32 PM
Bingee's Avatar
Bingee
Just do what the HD owners manual says to do. Put in some regular (dino) oil. Ride for 1000 miles. Drain it. Change the filter. Then go to syn if you like when you refill it with new oil. They've been building engines for over 100 years. So I trust they know how to break-in an engine.
Old Aug 15, 2014 | 01:32 AM
FlaHeatWave's Avatar
FlaHeatWave
I used the HD dino oil for the 1st 3 oil changes of the new Build, then went to Syn3
Old Aug 15, 2014 | 05:10 AM
mmats69's Avatar
mmats69
Hd 360
