Neutral question on 5 speed
Old 06-08-2011, 08:48 AM
Moon-dog's Avatar
Moon-dog
Moon-dog is offline
Default Neutral question on 5 speed
I have a 97 road king with 9000 miles on it. Here lately I am haveing a hard time getting it in neutral. It just won't go. Any suggestions? Anybody else had this problem.
No, I'm not a rookie, I ride everyday and have for 20 years. I just bought this bike about 4 months ago and it just started this about 2-3 weeks ago.
Thanks
Moondog
Old 06-08-2011, 08:50 AM
strongwood's Avatar
strongwood
strongwood is offline
I have the same problem
It is a dad gum dance to get it into neutral at a stop light
Old 06-08-2011, 08:54 AM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,222 Likes on 1,483 Posts
When's the last time you did a clutch adjustment? Think that would be the first place to start.
Old 06-08-2011, 08:57 AM
hobobiker's Avatar
hobobiker
hobobiker is offline
And if what Panz suggests doesn't fix the issue, I've seen the neutral indicator switch cause problems as they wear, but that's usually the exception. Also, if you haven't changed and/or checked the fluid level in a while that can contribute...
Old 06-08-2011, 08:59 AM
gary53's Avatar
gary53
gary53 is offline
Default Neutral
Check the old level in the trans. I have a 05 and what works for me is I have to go to 1st gear then back to neutral. It works almost every time.
Gary
Old 06-08-2011, 10:17 AM
Sharknose's Avatar
Sharknose
Sharknose is offline
+ a bunch on changing the trans oil.
Old 06-08-2011, 10:29 AM
barjbar's Avatar
barjbar
barjbar is offline
When I changed to synthetic trans oil it helped a lot on my RK. I'm switching my EG as soon as I put a thousand miles on it.
Old 06-08-2011, 11:15 AM
golfblues's Avatar
golfblues
golfblues is offline
Received 1,434 Likes on 874 Posts
If the primary is over filled neutral is a biatch!
Old 06-08-2011, 12:05 PM
bigred292's Avatar
bigred292
bigred292 is offline
I just bought a 98 RK Classic and this is exactly the same thing I've been experiencing at stop lights, etc.
I spend the entire red light trying to get into N. Kind of embarassing!
I then tried a couple of diff. things- found one that works for me.
As you're approaching the stop sign/light put it in N while the bike is still rolling-doesn't have to be going fast, just rolling.
This works for me everytime now-try it!
Old 06-08-2011, 07:24 PM
Other Sheep's Avatar
Other Sheep
Other Sheep is offline
OLD NEWS FLASH. When harley built the balanced twin cam motor for the softails in 2000 they tried to use the original trans that was in the evo bikes. But it was really difficult to shift. They (engineers?) discovered that the vibrations coming from the evo motor was allowing the tranny to shift a lot easier than it would with the smoother running tc.
Solution to finding neutral on an evo bike. Rev the motor a bit. You'll be surprised at how much easier it is to go to neutral.
Also the trans is designed to go to neutral only from first gear. Down shift to first and bring it up.
Hope that helps.
Quick Reply: Neutral question on 5 speed
