Anybody use Marvel Mystery Oil in the hog?
Old 03-17-2012, 05:03 PM
4 inch pistons's Avatar
4 inch pistons
4 inch pistons is offline
Default Anybody use Marvel Mystery Oil in the hog?
Noticed I was a quart low today and you just can't get Amzoil anywhere close by without a 25 mile trip. I went to Advance Auto and they did not have it, but I saw Marvel Mystery oil additive. I used this a lot back in the 70's in my big US auto V8s back in the day, but quit for some reason. So I bought a quart and added about half of it in the crank and put some in the tank.
I was not expecting any difference in the running--- I just wanted to raise the oil level without mixing brands. But I did notice a pleasant surprise in the smoothness (looseness) that the engine suddenly displayed.
Anybody else out there use MM oil in the crank case? Anybody else have a problem with it?
Old 03-17-2012, 05:07 PM
CobraEd's Avatar
CobraEd
CobraEd is offline
I always add some to the gas to lube the top ring & valves. Good stuff!
Old 03-17-2012, 05:27 PM
Jim Kraft's Avatar
Jim Kraft
Jim Kraft is offline
It is a little thin for Harleys, but 1/2 qt. won't hurt. All oils will mix ok. You could have put in Mobil1, or any other oil. Even dino would mix just fine.
Old 03-17-2012, 05:50 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,534 Likes on 4,632 Posts
Well, for one thing, it isn`t motor oil, so why put it in?
You were at an auto parts store, with shelves full of motor oil...
Old 03-17-2012, 05:59 PM
big cahuna's Avatar
big cahuna
big cahuna is offline
If your motor has any dirt left in it the mmo will clean it out. I put a oz or dos in the gas every other tank. I've seen it clear up a crappy running Honda, so that convinced me it will clean up a dirty fuel system.,,
Old 03-17-2012, 06:11 PM
4 inch pistons
Sorry guys--- I got a thing about mixing oils. May be part of my OCD issue, but it is my issue and my bike
I have seen the demo from years back where they mix 2 oz gas and 2 oz MM oil and set it on fire. The gas burns but the MM oil is left behind with lube capacity intact. I was impressed. It is not an oil, but an additive, and a good one at that. I was just wondering if others used it?
In the past I have added Seafoam, but I think I will start with the MM in the tank.
Old 03-17-2012, 06:20 PM
Dan89FLSTC's Avatar
Dan89FLSTC
All motor oils can be mixed, without a problem. Synthetic, Dino, it does not matter.
Old 03-17-2012, 06:27 PM
*NIGHT TRAIN*'s Avatar
*NIGHT TRAIN*
*NIGHT TRAIN* is offline
Another snake oil/additive thread...
Hot DAMN!
SportsterBob's Avatar
SportsterBob
SportsterBob is offline
.4/oz of MMO per gallon of fuel in the gas tank provides some lubrication on the upper cylinder walls and soaks into any carbon on the piston dome/combustion chamber/valves and burns off the deposits...Been using it since 1986 with no issues!
Old 03-17-2012, 06:48 PM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
It will clean your motor out real good. But I wouldn't run it very long in there. To thin of an oil for a Harley. Even mixed with what you were running. It's like a 10wt oil.
Quick Reply: Anybody use Marvel Mystery Oil in the hog?
