Primary/Derby cover gasket
08-15-2013, 03:53 PM
Has anyone ever re-used the primary/derby cover gasket? I took my cover off and remembered that it is the one thing I forgot to buy.
08-15-2013, 04:06 PM
I've reused that gasket at leas 6 times with o problem. Of course your HD dealer will tell you it will surely leak
08-15-2013, 04:11 PM
As long as its not torn or stuck to either surface. Torque the screws properly in the recommended pattern. AND USE LOCKTITE!!!!
08-15-2013, 04:35 PM
Quote:
Originally Posted by
Voldemort
if you're talking about the quad ring (on your 2010), i've reused mine at least 7 times with no issue. would be more, but i ended up trading the bike in on a new one.
08-15-2013, 04:41 PM
i changed the derby cover O ring and the primary cover gasket once in the 28 years i owned my 85.
08-15-2013, 05:02 PM
howitzer88
Locktite on those little bolts in aluminum?? No thanks.
08-15-2013, 05:20 PM
How far should clutch lever come out before clutch engages? About 1/4 to 1/2?
08-15-2013, 07:18 PM
hdbob2006
+1 on that, that's a good way to end up stripping those little bastards next time you have to remove it, totally not needed!
08-15-2013, 07:45 PM
When the gasket is fine, I do not bother to change it.... and those torx screws really grip tight to the cover so I never even considered loctite. I had enough fun last time getting a couple of them out.
08-15-2013, 08:16 PM
I changed my torx screws to allens, always reuse gasket.
