Newbie question - need to drill a tour pak
Gents,
as you can probably guess by the title of this post - I'm not very "handy" (and that is an understatement).
I've got an aftermarket tour pak (fairing factory) to which I need to install the docking mounting bracket. The tour pak came with the mounting plate, but not pre-drilled, so I need to drill 4 holes.
Is there some special bit I need to use for it, or will the regular do?
No, any standard sharp drill bit will do.
Step #1 lay the mounting plate on the bottom of theTour Pack, noting the aproxmant Locations of the holes.
Step #2 using painters tape (the Blue of Green) cover these areas.
Step #3 Now lay the mounting plate on the Tour Pack and mark these locations.
Step #4 Using a center punch or a very small drill bit (turning it by hand) make your drill starting marks.
Step #5 Using the correct size of drill bit (keeping the tape on) drill the holes at normal speed.
Step # 6 If needed, use an x-acto knife to smooth the inside of the drilled holes.
Your set to go.
Your set to go.
I'll add in run a small bead of silicone around the bolt holes after you run the bolt through before you tighten down the nuts and then put a little around the nuts. I even ran a small bead on the inside of the your pack around the bolt heads.
Your set to go.
Your set to go.
Received 4,314 Likes
If you have to enlarge the hole any run the larger bit backwards till you just get through the gel coat then you can drill as normal. This way the bit won't grab the gel coat and chip it out.
