tour pak quick removal
Old Apr 4, 2006 | 08:45 PM
notarheli's Avatar
notarheli
Default tour pak quick removal
I understand that when using the quick release/docking station for the tour pak, that you need to use a different license plate frame. Does anyone that's installed this have suggestions?
Barry
Old Apr 4, 2006 | 10:08 PM
Ram's Avatar
Ram
Default RE: tour pak quick removal
Mine is a quick release system for my Ultra travel trunk and didn't use any other set up for the license plate other then stock!
Old Apr 4, 2006 | 10:19 PM
PipeDADDY's Avatar
PipeDADDY
I have a quick release tour pack on my RG...stock lic holder (I guess I should change that....let me add it to my list)
Old Apr 4, 2006 | 10:26 PM
Red Road King's Avatar
Red Road King
I put a tour pack on my RK Classic and the stealer said I needed a laydown bracket, but I installed it without no problem.
Old Apr 4, 2006 | 10:33 PM
ultraclassic137's Avatar
ultraclassic137
It was not necessary for the installation, but I bought this bracket from Ebay and it was great quality.
Inexpensive Laydown License Bracket
Old Apr 4, 2006 | 10:59 PM
wglindsay's Avatar
wglindsay
Stock plate on my 03 RKC and the quick release tour pak works great!
Old Apr 4, 2006 | 11:04 PM
notarheli's Avatar
notarheli
What......you mean my dealer would actually try and sell me a license plate at $65 that isn't needed??!!! Well, I never.....
Thanks, I'll apply the saved $65 towards stage 1.
Old Apr 4, 2006 | 11:23 PM
RED E GLIDE's Avatar
RED E GLIDE
I have a 05 e-glide clasic and it came with a non detachable tour pac from the factory. The factory tag bracket suports the
rear of the tour pack mounting bar. I changed it out for one my friend removed from his RK custom. I think if your bike came
without tour pack then you can reuse your original tag bracket. But if it has a factory mounted tour and you are making it
detachable then you will need a different bracket.
Old Apr 4, 2006 | 11:28 PM
Harley Rulz's Avatar
Harley Rulz
This is the one I bought.It's worth the $$$$$$
ORIGINAL: ultraclassic727
Old Apr 4, 2006 | 11:35 PM
billnourse's Avatar
billnourse
You didn't say which bike you have. If it is a Roadking, Roadglide, or EG Standard that did not come with a tour pac you wil not need a different lic. bracket. It your bike came with a tour pac, (EG Classic, EG Ultra Classic) you will need to have a different license plate bracket as the brackets on these bikes are part of the tour pac bracket.
When I made the tour pac quick detach. on my EG Classic I used HD's laydown lic. plate bracket. It gives a very clean look when the tour pac is off.
Regards,
Bill
