tour pak quick removal
Old Apr 5, 2006 | 02:13 AM
Matt8643's Avatar
Matt8643
Default RE: tour pak quick removal
As other have said, only international bikes need a different license plate holder, domestic bikes are fine with stock plate holder and tour pak.
Old Apr 5, 2006 | 02:23 AM
notarheli's Avatar
notarheli
Sorry. Good point about what we are talking about.
It's an 06 EG Classic with factory tour pak. I will be installing the detachable mounts.
Old Apr 5, 2006 | 02:31 AM
Qball's Avatar
Qball
ORIGINAL: billnourse
You didn't say which bike you have. If it is a Roadking, Roadglide, or EG Standard that did not come with a tour pac you wil not need a different lic. bracket. It your bike came with a tour pac, (EG Classic, EG Ultra Classic) you will need to have a different license plate bracket as the brackets on these bikes are part of the tour pac bracket.
When I made the tour pac quick detach. on my EG Classic I used HD's laydown lic. plate bracket. It gives a very clean look when the tour pac is off.
Regards,
Bill
Ditto
Old Apr 5, 2006 | 11:41 AM
Loch's Avatar
Loch
Then you WILL need a new license plate holder.
ORIGINAL: notarheli
Old Apr 5, 2006 | 03:20 PM
wildwill's Avatar
wildwill
You DO NOT need to replace the tag bracket. I made the tour pak on my 99 EG detachable and used the stock tag bracket. Everything fit just fine.
However, the bracket did not look good because of the tour pak mounting tabs on the top. So I dremeled them off. End of problem. [sm=signs007.gif]
PS - I eventually replaced it with a bracket from a RK.
Old Apr 5, 2006 | 09:26 PM
craig62va's Avatar
craig62va
2006 road king classic,use stock bracket with detachable tour pack.
Old Apr 6, 2006 | 04:41 PM
FLHTC06's Avatar
FLHTC06
When I did my detach tour pak I had to go with a different (laydown) plate holder because I eliminated all hte other brackets used. *** ALSO *** Buy yourself the quick disconnect locks !! You don't want to be somewhere then realize your tour pack is GONE. I can remove mine and replace it with a sissy bay in under 60 seconds. Food for thought.
Old May 14, 2007 | 10:23 AM
kpb46's Avatar
kpb46
OK I'm a year late. But I would like to know what I need to make my Tour pac detachable on my 07 Ultra. PART #'s etc
Thanks
Old May 14, 2007 | 10:43 AM
tizone's Avatar
tizone
I would also like to know how to make the tour pack on an 07 Ultra qick detach.
Old May 14, 2007 | 01:52 PM
RainMaker's Avatar
RainMaker
I've been eyein one for my 07 UC.
Since I have all the detached fellas in one thread... have you had any issues with them? Do they vibrate, get loose? I had read in a another post where they were having problems after a year of on and off.
Anything we should add while installing it to ensure proper tightness?
