5 3/4 2014 Daymaker LED Headlamp Specific Question
Been searching the forum for 2 hours and cannot find an answer to this specific question:
New 2014 Daymaker Headlight now has 6 bulbs vs the previous 4 bulb design, with this change how is visibility during the daytime to other drivers?
Thanks!
Thanks!
I have that exact headlight. It is very good for night visibility but during the daytime the headlight is not as visible to other drivers unless they are almost directly in front of you.
With only the low beam on, the light is invisible during daytime unless you are directly in front of the bike. With the high beam on, the light becomes reasonbly bright from most viewing angles. Not as bright as an incandesent but acceptable.
I drive with high beams on during the day, low beam at night.
