How to Hard Wire Accessories via Cig Lighter
Old 07-30-2014, 02:13 PM
johntaylorny's Avatar
johntaylorny
johntaylorny is offline
Default How to Hard Wire Accessories via Cig Lighter
Looking for some help with accessories. I have accessories that need a cigarette lighter socket to plug into. Can I buy the female end cig lighter socket somewhere to hard wire into the bike?
I tried hard wiring the accessories directly into the hot battery terminal, but they melted. The plug actually reduces the voltage from 12v to 4v. So I need to plug the accessory into a cig lighter socket.
Also would I hard wire the cig lighter socket directly into the hot battery lead or should I wire it into thinner wires like the tail light?
Old 07-30-2014, 02:33 PM
mtgriz's Avatar
mtgriz
mtgriz is offline
Google cigarette lighter socket.
Old 07-30-2014, 02:34 PM
DeeRides's Avatar
DeeRides
DeeRides is offline
Kuryakyn has one that I have mounted to my bars. Works very well.
Old 07-30-2014, 02:38 PM
caberto's Avatar
caberto
caberto is offline
I did this with a $15 Bell lighter socket from Autozone. I think I wired it to the running amber running lights, so it's only on when the bikes on. Attached it to the right-side frame upright (for easy access when the bike's parked), and has been working great since I added it in 2010. It has a spring loaded lid (which I painted black), so when not in use, stays sealed. Can't tell it's there as it blends right in with the black frame.
Old 07-30-2014, 02:40 PM
LANGEFIFL's Avatar
LANGEFIFL
LANGEFIFL is offline
You should be able buy what you are looking for at any shop...
I have them on both my bikes.
There is also an adaptor that goes from the battery tender end (if you use one) to cig lighter.
Old 07-30-2014, 03:18 PM
Thumper09's Avatar
Thumper09
Thumper09 is offline
Mounted it under my seat and inserted a dual USB port plug in adapter.
http://www.ebay.com/itm/Black-Plasti...vip=true&rt=nc
Thumper09's Avatar
Thumper09
Attached Thumbnails How to Hard Wire Accessories via Cig Lighter-cigarette-lighter.jpg
Old 07-30-2014, 03:24 PM
hogcowboy's Avatar
hogcowboy
hogcowboy is offline
HD makes or has available one that plugs right into the accessory plug found behind the right side cover or under the seat. I installed it on mine on that right side cover. Works great.
Old 07-30-2014, 04:20 PM
adm's Avatar
adm
adm is offline
Received 2,460 Likes on 1,407 Posts
If the reason your previous one melted was because it needs 4-5V and is a USB adaptor plugged into a cigarette lighter socket, you can get dual weatherproof USB sockets that do the voltage conversion etc. I have one hard wired to my battery and routed to the bars. It's perfect for plugging iPhones and stuff into.
The benefit of a cig lighter socket is you can use it to power stuff like tire inflators from as well. But if it's USB you need, most of the cig lighter to USB adaptors are cheap chinese **** and will burn out regularly.
wombat457
08-14-2015 03:43 PM
elderberry99
05-27-2014 12:39 PM
Foodog
09-29-2010 11:18 AM
SeniorChief56
04-13-2010 08:46 PM
bobg1253
06-15-2007 01:30 AM
Quick Reply: How to Hard Wire Accessories via Cig Lighter
