Need Hot Wire
Old Apr 10, 2010 | 07:17 PM
SeniorChief56's Avatar
SeniorChief56
Veteran: Coast Guard
Default Need Hot Wire
I need to wire in my amp(TURN ON LEAD) to a wire that is hot when ignition is on only. I did find a wire to the tail lights but when I would plug it all back together, there was not enough power/amperage. What wire do I need to tap into near the battery?
Old Apr 10, 2010 | 07:47 PM
vickon's Avatar
vickon
When I installed my Elf amp the hot wire went directly to the + connector on my battery, for the "turn-on" signal wire I spliced into the orange wire at the lighter plug and for my ground I used one of the common ground points on the frame (next to the seat - left side). My bike is a 2008 FLHTC.
Hope this helps, got some pics, if you need them holler ... cybermunster@hotmail.com
Old Apr 10, 2010 | 10:02 PM
SeniorChief56
I don't think that works on a RKC,,,,no lighter plug that I know of
Old Apr 11, 2010 | 01:19 AM
Silver Fox's Avatar
Silver Fox
Use the wire to the tail light but hook it to a relay that is tied into your battery. The relay will get power from the battery only when the lights are on. That is how I wired mine, works good. Just get a relay at your auto store.
Old Apr 11, 2010 | 07:11 PM
SeniorChief56
what color wire am I looking for? Which side of the bike is it? Clutch lever or brake lever side?
Old Apr 11, 2010 | 08:03 PM
Silver Fox's Avatar
Silver Fox
I tied in with the black wire with purple stripe in that is in the wire harness and heads out through the rear fender. I pulled the pin out of the harness and tied in with it and put it back in.
Old Apr 11, 2010 | 08:07 PM
Silver Fox's Avatar
Silver Fox
Brake lever side
Old Apr 11, 2010 | 09:02 PM
fishcop's Avatar
fishcop
Default Hot wire
Senior Chief when I had my RK it had a hot wire inside the headlight nacalle. It had a red plastic end on it. I think it was supposed to be used if you wired something to the aux switch. Check inside to see if you have one.
Old Apr 11, 2010 | 09:04 PM
SeniorChief56
Fish..I'm sure there is one there,,but I want to do the wiring near the battery is,as that's where the amp is,,basically behind the rightside painted cover
Old Apr 11, 2010 | 09:08 PM
Panasoffkee's Avatar
Panasoffkee
I personally would wire it to the terminal on the ignition switch that supplies power to the bike.
