Best Air Filter Oil?
Received 1,936 Likes
Resurrecting this out of interest:
Whose using what in lieu of K&N, PJ1 or NoToil air filter oils and how is it working for you ?
I've read that Canola oil or chain saw bar oil is just as good, for example and was curious as to the extent people were using and recommending alternatives like these, or other commercial products as well.
"Its still winter".
"Its still winter".
actually the k&n oil is probably best for their filter. even if you think it is expensive, you do not really use that much. it has a dye marker in it to tell when it needs to be serviced. remember, the basis for filtration in the COTTON media.
a lot of oils in a can have carriers that can have a negative effect on the media and break it down. the 3-n-1 oil is a good oil if out of the dropper can but is too heavy to work with and it will last a long time before drying out. wd-40 is lite enough but the carrier is the ??? and it drys with a film. if you use wd-40 on one of our steels, it voids the warranty as this film will cause sticking on the changer assy and it attracts everything and even cigarette smoke which gunks the assy up making a total tear down for cleaning.
bar oil has a tackifier in it like stp and is extremely heavy and when washed, will form a thick milky substance. i would not use silicone oils either as the are resistant to water making it hard to clean and the carrier is suspect also.
if i am going to spend $$$$$ for a filter, then i will bite the bullet and use the recommended product.
HKMark23 (02-21-2018)
I'm fairly decided on using the bio friendly Simple Green, I've already got loads of, to clean my filter and I'll probably pick up a bottle of NoToil, which is cheap up here and purpose made for the filter.
Still, I'm open to ideas.
well that is really simple feat to over-come.
aerosols can be emptied and then used in spritzer bottles.
i buy in bulk machine cutting fluid and use a recharge-able aerosol can to spray while machining. i will try and post a jpeg, got mine from harbor freight moons ago.
http://rasomuro.info/images/index.php?p=79
just to give an idea, many out there.
some can be proprietary. not all oils are petroleum based like not all greases are. if the fluids are sealed from air getting to it, can last decades.
