Oil dumped into Air filter?
Old Aug 1, 2011 | 07:21 PM
raksasas's Avatar
raksasas
Default Oil dumped into Air filter?
About 2 months ago me a a couple guys go and see the Independent Shop, Jim's Cycles. While the owner, Jim, was showing something to one of them something I walked up on a conversation where he mention something about oil being dumped into the air filter. He mentioned a couple of things:
1. That on long rides the right side of the bike scan be cover in oil residue
2. Harley used to have the oil residue dumped in front of tire (or something)
3. Due to EPA, Harley made it so it dumps into the air filter
4. He (Jim) would get some hose and make it dump back to the ground to keep the bike/chrome cleaner.
He didn't go into much detail about this but I noticed today after my 1000+ weekend ride that i have oil build up on my right side of my Dyna (08 Dyna Superglide FXD). So now I am wanting to do this re-routing hose thing. Can anyone give me any guidance on it?
Old Aug 1, 2011 | 07:26 PM
Dirknar's Avatar
Dirknar
No guidance, sorry, but are you talking about Jims customs in spokane? My 02 lowrider has been spitting some oil out as well..
Old Aug 1, 2011 | 08:08 PM
raksasas's Avatar
raksasas
Sorry wrong Jim, I"m am referring to Jim's Cycle Shop in Axtell, TX.
http://www.jimscycleshop.com/
Old Aug 1, 2011 | 09:02 PM
8541hog's Avatar
8541hog
There is no problem letting it go back into the intake, it gets burned off that way.
I really wish my bike dumped oil in front of my tires
Old Aug 1, 2011 | 09:14 PM
rooti's Avatar
rooti
If it bothers you look into a crankcase breather kit and route it to under the frame. I find if I don't run my oil all the way to full it doesn't dump into the A/C
Old Aug 1, 2011 | 10:13 PM
blacknsilver's Avatar
blacknsilver
you will get some oil but if you are seeing a lot of oil running out then maybe you overfilled it a little
Old Aug 1, 2011 | 10:21 PM
ak47dennis's Avatar
ak47dennis
what a/c are you running? I have seen the screaming eagle "ventilator" style do this were it collects oil on the bottom of the filter. but mostly i tought of this issue as just being over full.
Old Aug 1, 2011 | 10:33 PM
paul s's Avatar
paul s
I'm venting to ground but it isn't going in front of my tire, I run it through the exhaust bracket on my Supermeg and it comes out off the side of my bike past where it could get on my rubber, it keeps the mist out of intake and burns cleaner.. You should also drill out the drains in the rocker supports for a better flow. I never saw oil on my bike before or after this mod, I think you "might" be a little overfilled.
Carmo-25
Oil Archive (no new posts)
Aug 22, 2016 07:26 PM
dbalogh
Jun 2, 2008 10:27 PM
brohrs
Oct 23, 2005 03:44 PM
Russell
Exhaust System Topics
Sep 19, 2005 09:06 PM
wingnut79
Aug 11, 2005 04:05 PM
