Remove ABS system 2012 FLHTC
Old 08-25-2016, 02:06 PM
soberjoe's Avatar
soberjoe
soberjoe is offline
Default Remove ABS system 2012 FLHTC
I converted my bike to a trike. That ended the ABS system. The sensors are off on the front and rear. I get the yellow trouble light now, but the bike brakes just fine.
Next I want to remove all the ABS hardware. Replace it with regular brake lines.
I'm wondering if the computer is going to freak out and cause me trouble?
Anyone have any experience with this sort of project? Thanks for the help.
Old 08-26-2016, 01:56 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Since you're getting the yellow trouble light, the computer is already starting to freak out. I'd talk to a Shop Manager or Senior Technician and see if there's a download that will erase just the ABS programming from the ECU.
Old 08-26-2016, 09:35 AM
soberjoe's Avatar
soberjoe
soberjoe is offline
So far everyone I ask just gets a deer in the headlights look.
Old 08-26-2016, 10:22 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Exclamation
I'm not surprised! You're asking more than I suspect you realise. The way electronics are integrated into modern vehicles doesn't make removing features easy, so disabling ABS isn't as easy as undoing a few nuts and bolts. It is probably easier to add it to your current rear brakes, are they on each wheel or central?
Old 08-26-2016, 04:37 PM
soberjoe's Avatar
soberjoe
soberjoe is offline
I don't have the sensors anymore. I had the front wheel set up for non abs and just remove the rear. Brakes work fine, the abs simply stops and lets the brakes work as non abs brakes. I do have the little warning light on the dash but I don't really notice anymore. I might just try disconnecting things one at a time and see what happens. I would just like to get rid of stuff that isn't needed. Keep things tidy.
rossWG
08-03-2021 09:56 PM
Joe from So Cal
11-15-2020 10:39 AM
Vinnie the tech
04-16-2017 04:46 AM
wavesnwheels
04-21-2015 03:54 AM
pled55
08-10-2013 06:12 PM
Quick Reply: Remove ABS system 2012 FLHTC
