Hard Kicking It Into Neutral?
I am a bit embarrassed. After many years of riding daily racking up a huge number of miles, I finally figured it out..........
If you have difficulty kicking the shifter into neutral, you may want to try what follows below. (THIS may be common sense for you but it was NOT for me, so maybe this will help others.)
I adjusted the clutch so when you release the clutch it starts to "catch" just a little bit later than normal.
I then took the bike out for a ride and WOW, what a difference. I was able to repeatedly kick it into neutral of the 1st time, time and time again for about 6-7 tries right in a row. What a DREAM it is now without hunting for neutral and missing it over and over and getting frustrated.
I acknowledge this may be common sense for you gearheads but I am anything but mechanically inclined. So I am figuring some of you others are out there a clueless as me. So maybe this will help........
BuzzCap7
BuzzCap7
BuzzCap7 (12-05-2016)
Sometimes I used to let the throttle out a little bit enough to move the bike inches, then pull the throttle back in and I can kick it into neutral.
Thank you tho my friend!
BuzzCap7
