Transmission Slippage??????
Old Apr 13, 2015 | 09:54 PM
big_daddy_g's Avatar
big_daddy_g
Default Transmission Slippage??????
On my way home from a weekend of visiting the family in Lancaster, I was cruising on the freeway at a steady 70 MPH in 6th gear. I needed to overpass a car so, naturally, twisted the throttle to gain more speed. As I twisted the throttle, the transmission dropped to 4th gear on its own! I eased off the throttle as soon as I passed up the car and it jumped right back into 6th gear! What the hell just happened?? I continued to replicate the problem to see if it was just a one time thing and long story short, it continued to down shift on its own every time I hit the throttle all the way home. Only sudden twists of the throttle makes it drop gears. What could be happening here?
Here are a few events that happened earlier in the day that may have caused the problem:
1. I took the bike a little over 100MPH. (I was feeling a little dare-devilish)
2. I performed a poor attempt at a burn-out.
3. I let my brother borrow my bike for an hour.
Any help would be great. Thanks.
Old Apr 13, 2015 | 10:56 PM
c-note's Avatar
c-note
Yikes! I'm no mechanic but did you open up the primary and have a look at your clutch pack? Maybe make the clutch pack and clutch cable adjustment and retest. It certainly can't hurt.
Old Apr 13, 2015 | 11:13 PM
slyedog's Avatar
slyedog
Definitely adjust the clutch first. The downshifting wouldn't be relative to the clutch being out of adjustment IMO. Check your shift linkage with bike off and on a jack. Manually cycle through the gears and feel for complete engagement. If it is not engaging fully then trans gurus can try to help. Thinking shifter paw or something may be messed up.
Old Apr 13, 2015 | 11:15 PM
HD Bobber's Avatar
HD Bobber
Shift fork might have gotten bent.....if you are positive that it's really dropping down in the gears. Clutch wouldn't drop gears down. When you get on it hard and you think it dropped a gear get off of it (to really make sure) and up shift to really find out what gear it's it.
Now if you feel like you get on it and it's "spinning" the rear wheel or making bunch of noise and not going much then yah your clutch is slipping/smoked.
My guess is that whome ever rode it last did something wrong shifting and that's where your problem began. Not to many issues floating around on HD trans problems. They're actually pretty solid units.
Old Apr 13, 2015 | 11:16 PM
TriGeezer's Avatar
TriGeezer
I'm not highly qualified, but that never kept people Dom commenting in the past on this forum. So, here is my $.02.
1) running it at 100 should not cause any transmission issues.
2) a burnout or 2 as long as you used the clutch...is not necessarily a great way to long term reliability...but should not cause this type of issue.
3) really...your brother borrowed the bike for an hour? How much rear tire did he shred off? Does he know you need to pull in the clutch between gear changes?
You might want to pull the transmission drain and see how much of your transmission is attached to the plug magnet. I'm betting...a lot.
Old Apr 13, 2015 | 11:36 PM
big_daddy_g
It's interesting that you mention that. I did notice a change in the friction zone of the clutch lever. I only have to pull the clutch lever in about half an inch in order for the clutch to disengage (or engage? I always get those two confused :/ ) Would a loose clutch cable cause the transmission to downshift on its own?
Old Apr 13, 2015 | 11:47 PM
1plumr1's Avatar
1plumr1
A Hondamatic in a Harley, now that's novel. JK. I would also look hard at the clutch. 1/2" to disengage is not good.
Old Apr 14, 2015 | 01:13 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
If you've got any warranty left, I'd take it in and use it.
Old Apr 14, 2015 | 10:32 AM
corliss@bakerdrivetrain.com's Avatar
Something is bent, shift fork or fork rod. Gears don't change on their own but if a fork is bent then 6th gear may not be getting fully engaged then you hit the throttle and it spits it out of gear and into the corresponding gear.
Old Apr 16, 2015 | 04:28 AM
stephenhelsel's Avatar
stephenhelsel
Anymore news on the the problem?
