Sportster stalls ALOT
I am new to riding and bikes in general. I started with an '89 Sporty. It has been running great, but lately it stalls at random times....I could be cruising along the highway then it just cuts out. I managed to get it home, but only after having it stall numerous times...I coasted into my driveway.
Any ideas would be truly appreciated.
Thanks
Thanks
RE: Sportster stalls ALOT
Had an 88 Sporty that used to do that. Turned out to be a bad ignition coil.
Check for loose electrical connections in the ignition wiring for starters. Maybe the main circuit breaker.
To help narrow things down, do the lights go off when it quits? Does it start up immediately, or do you have to wait a while to start it?
i have the same problem on my 1995 flht,,it runs great then just cuts off,,, head lights and all other electracle still works, it has to sit for about 30/40 minutes it starts back up and runs for about another 40 to 50 miles,,,sometimes even further,,then shuts off again,,over and over again,,help,,,anyone suggest an idea for me
