Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
What's up guys.. I'm building a mild 124" and I'm going to run the tts but would like to try to find a map that's close enough to run during the break in period before I dyno the bike. 10.5:1 comp, s&s 585 cams, stage 3 heads (vee-twin) 58mm hpi, 4.9 SE injectors, thunderheader. Anyone got a map I can use to get me close enough for a couple hundred miles? I currently have the new thundermax on the bike but I think the tts will be better for my application. I thought about leaving the tmax on for break in but I would like to remove all the wiring while the bike is torn apart. Thanks in advance
I have a map that i had made last year for a S&S 124 with 585 cams and a HPI 58 TB with 5.3 injectors.It is an open loop map and i was really pleased with that motor and map.If you PM me with your E-mail address i will send it to you.
Could I please get a copy of the MAP, I'm working on same build. Thank thank you!
