TTS + Mods...First Start??
So I'm installing cams (SE 204's), exhaust (Bassani Pro Street) and SE Heavy Breather all at th same time. Have a TTS tuner and headed to C&S for a custom map right after. However, I would like to crank it up and make sure everything is good to go before trailering to the dyno. Any recommendations? Download a generic map and install it on the tuner? Fire it up with the completely bone stock ECU? Any tips or recommendations? No plan to ride at all.
Load a TTS map that's close to your new mod setup per the TTS guide.
Start the bike and let it idle to warm up.
Run the cam analyzer per the TTS guide and make any necessary cam selection number change for the IVO.
Save the new map and reload to bike.
TTS suggests running the cam tool before any other tables are modified. And in some cases, the stock ECM map can produce very poor results when cams are changed out.
The cam analyzer is one of the programs used by TTS. Again, read the guide for some good info on how the analyzer works. I can't do the guide justice...
Correct! I just want to fire it up to make sure I got all the pieces and parts back together good...and obviously checking out the sound of the new pipes!!!! No intention of riding around or ripping it up prior to dyno/map.
So safe to assume the guide and all the info I can stand to read is included on the disc that came in the box?
I know my dyno guy will save a copy of the stock map. But yea, the intent of my thread was to see if it's fairly safe to crank it up with no tuner or at least try to download a generic map that close.
The Roadrunner
03-27-2012 08:00 PM
