Sensor failing without showing codes?
Old 07-30-2015, 07:04 AM
rjps2006's Avatar
rjps2006
rjps2006 is offline
Stage III
Default Sensor failing without showing codes?
Old 07-30-2015, 05:51 PM
greybeard122's Avatar
greybeard122
greybeard122 is offline
The crank sensor isn't supplied voltage from the system relay. The crank sensor is a 2 wire sensor that generates a small amount of ac voltage when the tone ring on the crank rotates right beneath it. The relay feeds your ecm, the injectors, the IAC, possibly your coil etc. It's possible the crank sensor is your problem. If you can check the resistance when it's in no start mode, and it's open, than that's no good. Test it cold and see what the resistance is. You can also hook up a dvom, put it on ac volts, and crank your engine. It will probably only generate a couple of tenths of a volt ac. If you can test it cold, record your readings, and test it when it won't start, at least you'll be able to eliminate it or condemn it as the problem.
Old 08-04-2015, 06:38 AM
rjps2006's Avatar
rjps2006
rjps2006 is offline
Stage III
MW2469
25
06-21-2021 09:46 AM
just plain john
10-26-2017 02:32 PM
53 pan
09-13-2012 08:18 AM
devils haircut
07-03-2009 08:41 AM
dogtags
General Topics/Tech Tips
10-25-2007 04:14 AM
Quick Reply: Sensor failing without showing codes?
