P0113 Code
Old Sep 13, 2012 | 07:33 AM
53 pan's Avatar
53 pan
Default P0113 Code
Hey:
I have a 04 Roadglide, and my anxioty light is on & off all the time. The air filter is clean, and I've replaced the Air intake temp sensor. I've cleared the codes like five or six times, but the light comes back !
Any input ???
Old Sep 13, 2012 | 08:18 AM
UltraNutZ's Avatar
UltraNutZ
excerpt from another post that may help you.
The Electronic Control Module (ECM) supplies and monitors a voltage signal (terminal 7) to one side of the Intake Air Temperature sensor (IAT). The other side of the IAT sensor is connected to a common sensor ground, which is also connected to the ECM (terminal 26).
The IAT sensor works by having a specific resistance at a specific temperature. As the resistance varies, so does the voltage on terminal 7.
At high temperatures, the sensor resistance is very low, which effectively lowers the signal voltage on terminal 7.
At low temperatures, the resistance is very high, alowing the voltage to rise close to 5 volts.
The ECM monitors this voltage to compensate for various operating conditions.
DTC P0112: IAT sensor voltage low
DTC P0113: IAT sensor open/high
You might check for:
- Poor connections on ECM and harness connector, damaged terminals, etc
- Intermittent faults "wiggle test" of wiring for poor connections
- Sensor may have become out of calibration.
The electrical diagnostic manual has a table of sensor temperatures and voltages to check sensor performance.
FREDStr33tbob
Exhaust System Topics
Aug 1, 2023 03:14 PM
Z
24
Nov 3, 2018 08:49 PM
devils haircut
Jul 3, 2009 08:41 AM
JefFLH
Apr 27, 2009 12:11 PM
Goaler34
Jul 8, 2008 05:23 PM
