Ignition Coil
Old 12-06-2016, 04:49 PM
txphatboy's Avatar
txphatboy
txphatboy is offline
Default Ignition Coil
Got a code for a bad front coil. Tested according to manual and primary coil test is around .8 - .9 ohms, which is just slightly above spec of .5 - .7. Secondary circuit tested around 3.09k ohms, both front and back. Manual says 5.5 - 7.5k ohms. I picked up a new coil from dealer and new coil tests around the same. This is for a 2001 FLSTF fuel injected. Is the 5.5 - 7.5k range correct? is 3.09k ohm reading indicate a bad coil? Thanks for any help.
Old 12-08-2016, 09:28 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,255 Likes on 3,627 Posts
Nothing wrong with the coil.. While you might have a bad plug wire, it's likely a bad primary wire connection from the ECM to the coil.
buellxb422
Ironhead
05-12-2016 07:07 PM
stealthisthought
EVO
43
08-18-2015 09:15 PM
thevajdos
06-19-2013 04:12 PM
ncottrell2009
Ironhead
10-18-2012 02:06 PM
daholken
03-28-2009 09:46 PM
Quick Reply: Ignition Coil
