throttle positioning sensor bad?
Was riding today and the bike started running rough. then would die at idle, had to keep it revved up to keep it running. It kept getting worse. Smelled gas very strong. I have the Daytona Twin Tech system and when I finally made it home I checked the TPS voltage and it was way off. I tried to set it at the reccommended voltage. It would not change at all. Could it be a bad TPS sensor. I there something else I should look at? Plugs are black from all the fuel.
Thanks
Tim
Thanks
Tim
bpwhalbany
09-20-2009 12:53 AM
