DTT and bad TPS sensor
Old Feb 1, 2009 | 03:56 PM
tarheelrdr's Avatar
tarheelrdr
Default DTT and bad TPS sensor
Posted in electrical section but I know a lot the touring guys have this system also. Riding today and started running rough and die at idle , Got worse. Finnally made it home and checked the TPS and it was way high. If you're familar with the DTT the TPS is set a .04 . This was all the way at the top of the chart and the throttle position was at 100 %. I tried to move the sensor and it would not change at all. Bad TPS? or is there something else to look for? Is there a way tocheck the TPS first.
Thanks
TIm
Old Feb 2, 2009 | 02:30 PM
tarheelrdr's Avatar
tarheelrdr
Got new TPS today and that was it.
Thanks anyway
Tarheelrdr
Old Feb 2, 2009 | 05:53 PM
Ram's Avatar
Ram
Thanks for the update. Glad that you found the culprit!
Old Feb 2, 2009 | 05:59 PM
PhilM's Avatar
PhilM
Hey Tim....
In the beginning of your message, I was kinda thinking IAC adjustment, but when ya said the TPS voltage was off the scale & would not adjust... I had to agree with your assessment.
Ya know, Chris will tell ya those things need to be replaced every couple years ~ at least for the TCFI-x bikes.
Be sure you used flat washers over the enlarged holes & "loctited" the screws.
Glad ya got it fixed!
BurgundyUltra06
Nov 1, 2024 01:37 PM
Gordon61
The Dyno Room
17
Oct 28, 2024 08:44 PM
lp
Jun 21, 2014 10:39 AM
jcasarez2000
Apr 20, 2013 12:27 PM
tarheelrdr
Feb 2, 2009 02:32 PM
