Reqest a little assistance from someone in the know...
Request a little assistance from someone in the know...
I know this probably needs to be in the EFI section but thought I would try here...
So I'm troubleshooting a rough running bike. If you didn't know there is such a thing as a 5 volt sensor reference used by our sensors (09 bike anyway) to communicate back to the ECM to make EFI adjustments etc.
Thing is when I measure at any of the sensors on this bike the voltage always reads 2.9 volts. I'm thinking it should be 5 volts (reference) right?
I've unplugged all the sensors and taken a measurement at the ECM and at "5v sensor power 1" and "5v sensor power 2" all I get is 2.9 volts. Yes there are two of the little devils!
I've had all sensors plugged in and at the sensor still getting 2.9 volts.
So....
Anyone willing to put a sewing needle or something on pins 5 (5 volts) and pins 1 (ground) of their TCA (Throttle Control Actuator) since it's so easy to reach and let me know if they see 5 volts or only 2.9 or something.
TCA plug can be plugged in or off - doesn't matter.
Bike needs to have ignition on.
Be careful. Don't cross the streams! Don't touch the two pins together.
OR has anyone ever battled the same thing and can tell me for certain that I should be reading 5 volts feed to the sensors?
I appreciate any help guys... kinda sucks not having a reference point to work with. If you find 5 volts it pretty much means I need a new ECM... $$$
Thanks!
lp
So....
Thanks!
lp
I'm reading the 5 volt feed to each sensor. The sensor return values are on other pins and vary depending on whatever the sensor reads.
Sucks man... I'm thinking to should read 5 volts always unless someone tells me different. (Pin 50+ to Pin 61- and Pin 68+ to Pin 62-) Each feed has an isolated ground just for it. It's crazy. lol
lp
lp
pin 5 to ground= 5.01 VDC
09 flhtc/ Fluke md88, ign on, motor not running
i'd suggest only that you isolate the ecm from all loads ...maybe a bad sensor or acuator loading it down.
costwise, maybe a thundermax would be a good ecm replacement option
mike
mike
Even rang out all wires from the ECM to all the sensors. Nothing grounded, full continuity where needed - all good.
Well this pretty much sucks. Guess I'm going to look into a thundermax.
Mike, since I know you are around these bikes a lot, ever seen this before? I mean I guess the ECM is just not making the full 5 volts... crazy.
lp
no, i'm only guessing
and you get same low voltage on both ECM pin 50 and pin 68 ?
anything that could have pooched the ecm? a tuner etc?
the voltage being 1/2 of reference make me wonder if 1 of a pair of dropping resistors has gone...finding it would be tough...replacing a resistor would be easy.
almost wondering if it would be possible to pull those 2 leads from the ecm and supply 5VDC with a transformer, or a resistor network.
I'd be interested in how you make out and how much it dings you.
mike
mike
I'm going to get another meter and check this thing front to back again.
I've been looking all over and have not found one instance of "low voltage" problems online. A few of No voltage only.
Maybe my Fluke 77/bn has finally let me down or something.
You'd think low voltage would set off all kinds of Codes but I'm getting nothing so I'm beginning to wonder if my test setup is accurate.
lp
