what makes a Throttle position sensor go bad
Old Sep 19, 2009 | 01:22 PM
bpwhalbany's Avatar
bpwhalbany
Stage II
Default what makes a Throttle position sensor go bad
What would make the bike throw a codes for TP Sensor Open/Low EFI. a new tps was installed on this bike not to long ago. now i'm gettin the code agian and the bike is running like ****
Old Sep 19, 2009 | 01:58 PM
DannyZ71's Avatar
DannyZ71
I don't know about bikes, but on cars, they operate based on voltage. Even a barely detectable fluxuation in voltage can cause them to malfunction. I had this problem a LOT on my Dakota R/T.
So it could be a fluxuation in power to it, or it could be something with the TPS itself.
Old Sep 19, 2009 | 06:49 PM
Nutbush's Avatar
Nutbush
Should be your basic variable resistor. Hook up a voltmeter (or better yet a scope if'n ya got one), and watch the voltage from closed to wide open throttle. Should be a smooth voltage curve with no glitches or dropouts.
Might grab a service manual and verify closed throttle voltage spec, and make sure it's adjusted correctly.
Old Sep 19, 2009 | 08:33 PM
stamper5498's Avatar
stamper5498
I ain't that smart
Old Sep 19, 2009 | 10:21 PM
codyshop's Avatar
codyshop
As with most things on your bike, they were supplied by the lowest bidder.
Old Sep 19, 2009 | 11:48 PM
Juve996's Avatar
Juve996
I heard some time ago on this forum that using the wrong attachment hardware for the air cleaner bracket may damage this sensor. Do you have an after market A/C? If you look at the attachment harware that secures the backplate to the throttle body, the threaded part may travel too deep and hit the sensor causing damage. I don't remember what model bike or which A/C kit they were talking about but if that's the case you will damage this sensor every time.
Old Sep 20, 2009 | 12:46 AM
harleydavis's Avatar
harleydavis
What he said. Thank goodness for throttle cables!
Old Sep 20, 2009 | 12:53 AM
gearjamster's Avatar
gearjamster
check all your connections and make sure they are tight and dry, i had some electrical probs the other day seems the plastic plug wasn't able to lock closed but i got it to click and problems are all gone road like the wind today and never once did it stutter.
Z
Jun 5, 2024 12:50 PM
lp
Jun 21, 2014 10:39 AM
tarheelrdr
Feb 2, 2009 02:32 PM
Taterdog
May 14, 2007 10:42 PM
