codes
codes
I just loaded a new map into my bike for the first time with sert. used 1690 stage 3 map it has arc turned on.
I am getting 2 error codes after I loaded map. P1655 and P0031. I cant find these codes on any codes sheets I have seen posted in the site . anyone got better lists to tell ne what they are. I will have to turn arc off since I haVE MANUAL decompression releases, didnt have the right jig at dealer to do hole in center of head. sert doesnt show any error codes in codes section when I scan.
Do you know how to clear your codes by use of your handlebar switches?
If not, do a site search on codes. That info has been posted many times and it will tell you how to do this, if this is what you are asking.
Have you changed your pipes? If so, look at your sensors for a loose plug or broken/skinned wire could even be a bad sensor. If not, see your dealer for warranty repairs.
All the code means is that the ECM is not reading the proper voltage from an 02 sensor.
I'm sure FM will tell you the same thing.
