Starter won't engage when Bike is hot, Battery is good. Starter will engage cold.
Old 08-10-2013, 09:31 AM
TimLScheffer's Avatar
TimLScheffer
TimLScheffer is offline
Default Starter won't engage when Bike is hot, Battery is good. Starter will engage cold.
When the Bike is cold the starter engages and it starts normally. After riding for thirty minutes or so then stopping, I turn it off... then start it a couple of times... After sitting for about five minutes the starter won't engage. I hear the solenoid click but the starter won't engage... Even if I put jumper cables on it... After the Bike cools down, the starter will engage again? My Mechanic put on a new battery, a new starter and a new voltage regulator... I don't think it needed any of those... I am suspecting a problem with a ground connection somewhere from the battery to the starter. What would make the starter not engage when when the Bike is Hot, but engage when cold... My Bike is an 07 Ultra Classic. If you have an 07 Ultra and the Compensator has not been replaced with the Screaming Eagle Compensator get that done. The Original one is defective... when it starts going bad it sounds like a washing machine coming apart when trying to start the Bike Hot. Terrible noise. You can sometimes get it to start by putting it in gear and rocking the bike to move the engine a little... I don't know why that worked but it did... any how the SE compesator fixed that problem about thirty thousand miles ago...
Old 08-10-2013, 06:47 PM
Assegai's Avatar
Assegai
Assegai is offline
The starter picks up it's ground thru the (2) mounting bolts on the inner primary. They have easy access and I'd check them first.
A starter clutch that is going south will at times make one gawd awful screech when the engine is hot. A kit runs about $150.
Old 09-03-2013, 09:48 AM
TimLScheffer
Default Why would the starter ground only be bad when the hot
Why would the starter ground at the mounting bolts only be bad when the bike is hot?Are you talking about where the bolts on the starter itself?
marktruckee
EVO
02-24-2016 07:20 AM
kitehog
04-23-2014 05:11 PM
xwhyz1959
11-21-2013 02:24 PM
watindes
EVO
09-29-2013 10:48 AM
johnfairclough
07-26-2012 07:32 PM
Quick Reply: Starter won't engage when Bike is hot, Battery is good. Starter will engage cold.
