Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Hi there, can anyone help with a problem Ive got, the bike is a 1986 FLH but have got a problem with the starter not disengaging, just keeps running, previous owner had fitted a battery isolation switch on the lead from the solenoid to starter, they put a new solenoid on, checked on bench, works fine, new pinion clutch fitted to starter. Would appreciate any tech info and like to hear from anyone that has had a similair problem. Many thanks
