2017 Engine Oil Light
#33
My Ultra Limited in for engine change for this problem. My oil light came on the first day after hitting operating temp at idle. Made it to 1000 mile service, running great. Oil light on but oil still flowing. Metal fragments in engine. Don't have all the details, but Harley not taking chances, going straight to engine swap.
#34
Interesting,
So how does this play with your registration since the engine #'s dont match anymore. I know in CA they are sticklers for that kind of stuff. Does the dealer contact the DMV.
Didn't know that little of damage could warranty a new motor. See if you can replicate the problem again once the new motor is in
#35
Interesting,
#36
It's interesting that you had low pressure and the damage appears to be in the scavenge pump.. Doubt the ding was the problem unless it somehow managed to damage the feed side.
#37
#38
That explains it.. Thanks.. I knew the pumps were different but all the stuff I've seen so far show the feed gerotor being smaller. So it's the feed side of the pump that pushes oil through the heads? Do they simply use an orifice to control flow ? Or something else?
#39
I get the check valve bit and sub supplier QC issues but where's the metal shavings coming from that are big enough to take out heavy gears that size ? That would have to be some substantial stuff to be floating around inside a new engine. That one worries me and nobody seems to be focusing on that little glaring issue.
#40
