2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
I dropped my bike off for new wheel bearings
Old 09-12-2016, 02:55 PM
rwven's Avatar
rwven
rwven is offline
Default I dropped my bike off for new wheel bearings
under warranty. The ABS bearings on on backorder from the factory. I'm thinking that they are having a lot of failures.
Old 09-12-2016, 03:02 PM
micmoren's Avatar
micmoren
micmoren is offline
what symptoms was it showing? I think I may be having an issue too and need to take it to the dealer to have it checked. When I apply the breaks, either front and back together or one or the other by themselves, I will intermittently hear a sound coming from the front.
Old 09-12-2016, 06:59 PM
rwven's Avatar
rwven
rwven is offline
I knew they were bad when I started seeing rust colored stains on the wheel hub around the bearings any time I washed the bike or rode in the rain. By the time you see those stains the bearings are bad. I pulled the front wheel and both the bearings are definitely bad. On the front wheel one of the bearings had already been replaced under warranty just 6000 miles ago. The other one (ABS side) has 21000 miles on it. I'm not sure how the bearings in the rear wheel are. The two in the belt pulley felt a little rough to me when I had the wheel off 6000 miles ago, the two in the wheel hub felt fine then. The service writer said they'd check them for me because there have been a lot of failures.
Old 09-12-2016, 08:54 PM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
Power wash is the biggest enemy of HD wheel bearings that's why I rarely wash our bikes and always tell the shop not wash our bikes during service.Went thru few set on our 07 and 08 UCs but it all stopped after stop using the power wash and stopped spraying the wheels with a hose.
Wildon883R (09-13-2016)
Royal Tango's Avatar
Royal Tango
Royal Tango is offline
So, if I see some rust colored stains around the wheel hub (Which I do), my bearings are going ?
Old 09-12-2016, 10:02 PM
BlueBeast's Avatar
BlueBeast
BlueBeast is offline
No worries ... they all do that, soon as they get their next shipment of bearings from China you'll be good to go .... at least til you have to put new rubber on again.
Old 09-13-2016, 04:25 AM
Wildon883R's Avatar
Wildon883R
Wildon883R is offline
+1 on this my bike gets bucket no pressure washed once or twice a season and gets cleaned with Original Bike Spirits the rest of the year. Pressurized water of any time is a no no for just about any part of the bike.
Old 09-13-2016, 04:35 AM
Ron750's Avatar
Ron750
Ron750 is offline
Received 16,515 Likes on 6,271 Posts
I have washed my 2003 for 5 years with a hose (not a pressure washer). No problems. Pretty sure that that was before they cheaped out on bearings.
I think it's despicable what they charge for new Harleys. They should be able to provide reliable OEM bearings, made in USA.
Old 09-13-2016, 04:38 AM
hardwork2's Avatar
hardwork2
hardwork2 is offline
my 16 road king had to have the front bearings replaced with a little over 2000 miles on it.
They were making a grinding sound.
rwven (09-13-2016)
Old 09-13-2016, 05:36 AM
rwven's Avatar
rwven
rwven is offline
I never power wash...ever. The hose nozzle I use is a high flow low pressure style and even then I don't direct it on the wheel bearings. I do ride in the rain.
Quick Reply: I dropped my bike off for new wheel bearings
