2015 FLHTK upgrade suspension
If you go to Ohlins 13" shocks, like 3-3s from Howard at motorcyclemetal, they will sit about like 12" shocks, but have a much nicer ride.
I put them on my '15 Limited Low & the ride height is pretty much unchanged.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Terry G (09-17-2016)
Question
Who would ever tell you with a straight face that Touring shocks need rebuilding after 20K miles? That simply is not true unless you do not clean the shocks. Any shock other than HD air shocks with the bellows get dirt drug up from the shaft past the scraper seal and into the shock oil. Every shock without a rubber boot. If you maintain the shocks by keeping the shafts and threaded body clean I have seen on average 35K Miles but I just did a set with 40K+ miles on them and the oil and cavity was very clean. Track or motocross shocks are a different story entirely. I do this job virtually every day. Every shocks oil degrades with heat as that is just the nature of the world we live in. I do not know who told you that a shock costs only $100 to rebuild them. Maybe that is that companies labor rate only.
