2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Outer fairing removal for sirius install
Old 05-26-2014, 05:34 PM
brownie374's Avatar
brownie374
brownie374 is offline
Stage II
Default Outer fairing removal for sirius install
Got a new Ultra Limited my wife bought me the sirius module for my birthday looks pretty easy to install but before I start the install are there any tricks for removing the outer fairing? Looks like a few screws by the windshield and 2 screws on each side on the back and also remove the headlight ring?
Old 05-26-2014, 05:41 PM
jstrenn's Avatar
jstrenn
jstrenn is offline
No need to remove headlight ring. Put a towel on your front fender to be safe, and guys also put socks over their passing/driving lamps to prevent any scratches. Pull the 4 screws on the back (2 on each side) then pull 2 outside screws of the windshield. Now the 1 middle screw is the only thing holding the outer faring. loosen the middle screw and pull out the windshield, then cradle the fairing with 1 hand and remove the screw. Once you pull the fairing back a few inches reach inside and unplug the headlight and its off!
Old 05-26-2014, 05:44 PM
TenMidgets's Avatar
TenMidgets
TenMidgets is offline
Add a weather strip to the windshield before you pout it back on to keep water out of the faring. I used Mastic tape, then bough some rubber weather stripping. There are two large gaps between the screws. I did not like them and I don't let Harley Wash my bike after servicing because of them.
Old 05-26-2014, 05:51 PM
brownie374's Avatar
brownie374
Stage II
Thanks for the fast reply! Great info
Old 05-26-2014, 06:05 PM
01XLH's Avatar
01XLH
01XLH is offline
I'll add that if you've taken fairings off previous bikies, it's much easier these days.
Old 05-26-2014, 08:48 PM
dontdropit's Avatar
dontdropit
dontdropit is offline
Yes it is
Old 05-27-2014, 05:33 AM
Gunnysgt's Avatar
Gunnysgt
Gunnysgt is offline
Harley did a great job removing the two evil screws that are on the bottom on the earlier models. Those two were always a real PITA to remove and reinstall. This outer fairling is much easier to work with. Just took mine off yesterday for the 4th time.
Old 05-27-2014, 04:31 PM
offthewall's Avatar
offthewall
offthewall is offline
Yep, it's that easy. I used the tube sock technique as well. I installed internal antenna's and it was a breeze.
Old 05-27-2014, 08:03 PM
Ghostrider1967's Avatar
Ghostrider1967
Ghostrider1967 is offline
You might want to consider mounting the Sirius antenna on the dash instead of inside the fairing? Changed mine and it improved the reception.
Attached Thumbnails Outer fairing removal for sirius install-2014-05-27-20.50.10.jpg
Kenneth452
Harley-Davidson Street
02-28-2016 12:11 AM
SamB
03-15-2012 01:21 PM
Rhinohd
07-31-2009 11:51 AM
07Eglider
06-01-2008 07:44 PM
cemax12000
General Topics/Tech Tips
05-20-2006 02:18 PM
Quick Reply: Outer fairing removal for sirius install
