Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Problem Shifting and disengaging
Old 06-03-2015, 09:49 AM
thrasher80's Avatar
thrasher80
thrasher80 is offline
Stage IV
Default Problem Shifting and disengaging
when I pull my clutch the foot pedal will not switch gears unless I give it throttle. also the slack on the clutch changes as I ride.. sometimes it goes all the way back and sometimes theres too much slack. some times when I pull the clutch it doesn't completely disengage and if will stall if I come to a stop. I have adjusted my clutch and replaced the cable and the problem still exists. PLEASE HELP!!!
Old 06-03-2015, 09:57 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
Check your throw out bearing.
Old 06-03-2015, 10:28 PM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is online now
+1 and make sure the adjustment is done with the powertrain cold.
Old 06-30-2015, 09:34 AM
thrasher80's Avatar
thrasher80
Stage IV
Im going to order a plate kit, a spring, and a throw out bearing... just need to figure out which one of the two throw out bearings I need.
Glen St. Mary
07-25-2018 03:15 PM
rudown
Engine Mechanical Topics
10-09-2015 07:04 AM
Jcegan
EVO
10-17-2014 05:08 PM
SwiftyBKells
03-13-2014 07:18 PM
Snagz
EVO
02-27-2009 09:10 PM
Quick Reply: Problem Shifting and disengaging
