1990 flstc
Old Oct 16, 2014 | 02:58 PM
Jcegan's Avatar
Jcegan
Stage III
Default 1990 FLSTC Clutch Problem
Hello Everyone, I've been trying to rely on myself more than the dealership for maintenance lately but I am stuck. If anyone could offer any advice I would appreciate it greatly. I have a 1990 heritage. I was riding the other day and my clutch got progressively sloppy. As I was pulling into my garage pulling in the clutch was almost useless as giving throttle would pull my bike forward into the garage even with the lever pulled in. I have done the clutch adjustment procedure per the manual twice. Each time the bike operates fine for about a mile then the clutch gets progressively sloppy and does not want to shift through gears. Also notice a high pitch whine when clutch is pulled in around primary. When I shut down in the garage my cable will have about 1/4" of slack where it had a little less than 1/8" to start. What are your thoughts?
Last edited by Jcegan; Oct 16, 2014 at 03:02 PM. Reason: Spelling and title change
Old Oct 16, 2014 | 03:46 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Check your spring plate.
It is in the middle of your fibers and steels in the clutch hub.
After that check your transmission drive pulley.
Old Oct 16, 2014 | 07:09 PM
Beemervet's Avatar
Beemervet
Throwout bearing?
Old Oct 16, 2014 | 07:51 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Agree with Texas and Beemervet.
I suggest you first remove the clutch release cover from the right side of the transmission and check the throwout bearing, because that gasket only costs about 2 bucks...
If the throwout bearing looks good, get into the clutch and check the plates and discs.
While you are there, remove the adjuster plate from the clutch and check the torque on the clutch hub retaining nut.
If everything looks good, it could be that the clutch cable is giving up the ghost.
Old Oct 16, 2014 | 10:34 PM
Tom84FXST's Avatar
Tom84FXST
Most likely problem with the symptoms you describe...you can replace it, or eliminate it with a few extra clutch plate/discs.
Old Oct 17, 2014 | 08:36 AM
Jcegan's Avatar
Jcegan
Stage III
Thanks everyone for the suggestions. I'll dive into it and start sorting through it.
Old Oct 17, 2014 | 02:55 PM
grbrown's Avatar
grbrown
Let us know what you can find, so we can give any follow up advice.
Old Oct 17, 2014 | 03:59 PM
texashillcountry
Dirt don't hurt
Cam, carb, pipes, ignition the advice here is endless!!!!!!!!!
Old Oct 17, 2014 | 05:06 PM
Jcegan's Avatar
Jcegan
Stage III
Excellent, will do. Thanks guys
Old Oct 17, 2014 | 05:08 PM
texashillcountry
Dirt don't hurt
Tell you what, just send me your credit card and I will send you all the parts you need!!!!!
Rusty Axle
Shovelhead
17
Jul 7, 2021 05:20 PM
mikeawin
Jun 29, 2017 10:31 AM
tonycap
EVO
14
May 24, 2013 11:44 AM
krh1326
13
Aug 18, 2010 07:16 PM
jcarson
Ironhead
16
Apr 26, 2008 01:48 AM
