breather gear missing tooth
Old Oct 10, 2014 | 04:18 AM
apples402's Avatar
apples402
Default breather gear missing tooth
Bike was making an odd noise and whining, took cam nosecone off and found plastic breather gear was missing 1 tooth. My question is do i just replace? I don't see anything else wrong, cam chest clean. 1992 dyna 50k 5000 on new top end. Am i looking for something else that may have caused this? Bore is a little scratched up but i spun gear easily.
Old Oct 10, 2014 | 05:01 AM
Tom84FXST's Avatar
Tom84FXST
Depending on how much it is scratched, you may have to have it bored for an over-sized gear...if it doesn't seal properly it will puke oil out the breather constantly. I would do everything possible to find the missing tooth.
Old Oct 10, 2014 | 05:37 AM
Spanners39's Avatar
Spanners39
This is very common, the scratches in the bore are usually just from normal wear and tear, the breather is sacrificial.
I have seen them lose 3 teeth and just digest them with no ill effects. On the rare occasions you find them they are usually in the bottom of the cam chest but it is best to try to locate it by flushing the oil lines and galleries and inspecting the oil pump but you may never find it.
Old Oct 10, 2014 | 04:30 PM
apples402's Avatar
apples402
Thanks guys, maybe got chipped when i ran the cam bearings through the motor and just now decided to come apart it is just one tooth and only about half is gone. Had to order gear 5 days. I will clean in the meantime.
Old Oct 10, 2014 | 05:26 PM
aces&8s's Avatar
aces&8s
I would go with a S&S reed breather, never have that problem again
Old Oct 10, 2014 | 05:45 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Old Oct 10, 2014 | 06:30 PM
Beemervet's Avatar
Beemervet
Absolutely
Old Oct 10, 2014 | 11:49 PM
apples402's Avatar
apples402
Do the plastic gears just break down and get brittle with age? Hope this is the cause of my noise and not a symptom of something else.
Old Oct 11, 2014 | 04:40 AM
Tom84FXST's Avatar
Tom84FXST
1992 dyna
S&S states the reed breathers are for 93 up only...ie a "top breather". Lots of people have had problems installing the reed valve on a "bottom breather" motor. Harley changed from bottom to top breathing mid year in 92...so you need to check and see what your motor is before going that route.
https://www.hdforums.com/forum/oil-a...em-on-evo.html
Old Oct 11, 2014 | 11:14 AM
apples402's Avatar
apples402
It is a bottom breather, thanks I was considering this too.
