Rear 20mm Pulley swap question
The issue I’m having is with the 70T/20mm pulley. The trans pulley change went exceedingly smooth so something had to gum up the job. I mocked up rear wheel to check belt length. Everything was going smooth until I started rotating rear wheel. Belt walks inbound until it is stopped by the sidewall. Pulled it back apart and quickly found my screw up. Stock 66T is ~29mm wide at axle and the 70T is ~15mm. Is there an OEM or Aftermarket 14mm Spacer to place behind the pulley? I’m guessing the thinner pulley was not from a 200mm swing arm set-up. If calculations are correct, with the Andrews 30T tranny and stock rear wheel pulley overall ratio is a 2.97 (stock is anemic 2.79) and the 30T/70T combo is 3.15. I hear tell of a 68T international pulley exists along with a 64T Japan pulley. Does anyone know if the 68T pulley is for a 20mm belted 200mm tire? And if so anyone know where I can score one? Sure would like to ride this season........
What type of bike?
Dyna wise, I am running the 68T International rear pulley along with the Andrews 30T front. The hub of the 68T was .10" thinner than the stock 66T but the outer part of the pulley was .10" thicker so it seemed to offset the thinner hub and lined up well. The 68T is designed for a 1.125" belt but I am still running my stock 1" belt and it rides on the outboard part of the pulley - planning on getting a 1.125" belt.
the wider the tire the thinner the belt needed? And the rim is going to be wider so a pulley with less of an off set (thinner) would be needed? If I'm understanding correctly. It is normal for the belt to walk inbound when tire is rotated backwards. And also walk out when rotated forwards. If it walks inbound no matter how you rotate the tire then there is an alignment issue. the rear pulley is what guides the belt not the front drive pulley as long as they are aligned the rear pulley will guide the belt were it needs to be on the front drive pulley. As long as the belt is not rubbing the tire and the pulleys aren't shaving/wearing out the belt sides your good.
Road King Kid
05-07-2010 05:21 AM
