Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Oil Leak--HELP!!!
Old 07-05-2015, 11:05 AM
JerryDinMD's Avatar
JerryDinMD
JerryDinMD is offline
Default Oil Leak--HELP!!!
Developed an oil leak about dime to quarter size after riding-wont leak on 15-20 min. idle-not engine oil-can NOT find the leak-have heard possibly leak from seal and/or sleeve from shifter linkage going into trans.- what I can see with a light from under and over-it DOES look like it could be a little something around the linkage going into the trans.-what's the best way to get to this? Do I HAVE to remove the entire outer case to get to it? All I've done is look and try to figure out how to get to it so far.---Thanks alot
2011 Superglide w/ forward controls
Old 07-05-2015, 12:39 PM
97 dyna lowrider's Avatar
97 dyna lowrider
97 dyna lowrider is offline
Your description is making it very hard to tell anything. If it's leaking from the outer then you just need to replace the gasket no big deal. If it coming from behind the inner primary then everything has to come apart.
Try to get a pic
Old 07-06-2015, 11:53 AM
djl's Avatar
djl
djl is offline
Received 2,031 Likes on 1,499 Posts
If you are saying that the leak occurs after a ride, leaves a spot about a quarter size and then stops after 15-20 minutes; that's classic symptom of inner primary bearing seal leaking.
Steve Sportster
06-05-2019 04:09 AM
Frank Block
08-10-2017 03:05 PM
tonrcsmc
02-17-2016 11:20 AM
Kaycee
04-30-2013 06:49 PM
HoolyNI
09-15-2012 09:09 AM
Quick Reply: Oil Leak--HELP!!!
