Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Transmission Compatibility 1997 FXD Dyna Super Glide
Old 07-13-2015, 05:00 PM
jdornski's Avatar
jdornski
jdornski is offline
Stage III
Default Transmission Compatibility 1997 FXD Dyna Super Glide
Hi from a HD newbie.
I just bought a 1997 Dyna Super Glide.(FXD). It has either a faulty clutch or transmission. There are lots of HD transmissions on e-bay. How do I figure out compatibility with my FXD.
Old 07-13-2015, 05:08 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,816 Likes on 3,318 Posts
I would test both the Clutch and the input shaft before I would just start to order things, Take off the primary cover and confirm that your compensator and chain are all good, Then move to test and inspect the clutch. And don't forget to get a manual. If all that tests good then move to the trans.... But GET A MANUAL.........
Old 07-13-2015, 06:17 PM
jdornski's Avatar
jdornski
jdornski is offline
Stage III
Default Have a manual
Thanks for the tips.
I have the official HD manual. I have had metric bikes since 1968 but now find HD nomenclature confusing.
Old 07-13-2015, 08:08 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,499 Likes on 4,612 Posts
Since you don`t know enough about the drivetrain to figure out which one is the problem, you should keep your money in your wallet and ask for some help finding out what the problem is...
Describe the problem, lots of help here...
Old 07-14-2015, 09:13 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
Any gearset from 1990-2006 *(except 06 Dyna) will work if it is the transmission that's bad. The shift system and shifter pawl will be different in 98 and up models but the gearset itself will work.
Old 08-18-2015, 01:24 PM
jdornski's Avatar
jdornski
jdornski is offline
Stage III
Default Lucky Me
Thanks for the last post as it was the most helpful
Anyway, I got the tools out and took of the primary case cover off.
The problem was that the plastic chain tensioner shoe was broken, caused by the previous trained mechanic leaving the pulley stop tool in the primary case to rattle around. Lucky it did little damage and did not jam the chain or pulleys.
$50 for new shoe,gasket and fluid and the bike is back on the road.
(and I am ahead one pulley stop tool as well)
lownslow
EVO
18
02-01-2018 12:12 PM
Bob>C
06-09-2017 02:55 PM
WhiskeyHarley
09-15-2014 07:00 PM
blackmopar
02-21-2009 02:41 PM
FLHDRIVER
04-13-2007 11:24 PM
Quick Reply: Transmission Compatibility 1997 FXD Dyna Super Glide
