Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
cluch cable
Old 07-19-2015, 09:12 PM
richard637551's Avatar
richard637551
richard637551 is offline
3rd Gear
Default cluch cable
hello needing some information i have a 1972 ultra flh shovelhead needing to know if my cluch cable is too long will it affect the transmission in any way when i adjust the clutch to the harley spec slight resistance then 180 counter clock wise the adjust clutch cable till there is about the thickness of a nickel between the cluch handel and the clutch cable having an issue with shift from 2nd to 3rd when i shift from 2nd to 3rd it slips back into nutral just wondering if the cable is to long and has to be adjusted all the way out is it causing the clutch to not fully disengage harley calls for a 51" cable mine is 59" any answer would be great thank you
Old 07-19-2015, 10:21 PM
heybaylor's Avatar
heybaylor
heybaylor is offline
short answer , no.
the tranny will shift without the clutch, and stay in gear.
the clutch just allows smooth transition .
mitchxc700
06-23-2013 03:20 PM
machm1969
05-07-2013 05:00 PM
schwinnanator
EVO
07-15-2012 10:54 PM
Bleachey
EVO
09-03-2011 09:18 PM
skos
10-23-2008 03:46 PM
Quick Reply: cluch cable
