Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Main shaft seal
Old 07-20-2015, 08:30 PM
prplglide's Avatar
prplglide
prplglide is offline
Default Main shaft seal
This past winter, I had to replace the transmission main shaft seal on my 96 fxdwg. There were no leaks until about a month ago. So, I poured some fluorescent dye in the trans oil, and it was, indeed leaking.
I removed both the inner/outer primary and the trans sprocket and the seal is leaking down toward the bottom.
My questions are these:
1. Is there a way to install it properly with out using the seal installation tool?
2. The manual also says to use loctite 601 sealant. Last time, I used something similar to yamabond; which apparently, didn't work very well. Has anyone used loctite 601, or equivalent?
3. Does anyone have any tips for a leak free install?
I don't want to take this thing apart again if I don't have to.
Thanks for your help/comments/advice.
Old 07-21-2015, 05:28 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
I found a piece of large PVC and tapped the seal on. They go on fairly easily.
Old 07-21-2015, 07:30 PM
prplglide's Avatar
prplglide
Never thought of that. Good idea!
Old 07-21-2015, 07:39 PM
soft 02's Avatar
soft 02
soft 02 is offline
Been doing this about 20 years. Got a few good ideas.
Old 07-21-2015, 07:44 PM
prplglide's Avatar
prplglide
After doing some more looking today, it appears that the seal is not the culprit. It looks like it's leaking between the main drive gear shaft and the inner race of the bearing. How the hell it started leaking from there, I have no clue.
Please see the pics:
Old 07-21-2015, 07:45 PM
prplglide's Avatar
prplglide
Well.... I hope you can come up with one more for me. Take a look at where it appears my leak is coming from.
Old 07-21-2015, 07:49 PM
soft 02's Avatar
soft 02
soft 02 is offline
Input shaft seal. Drill a 1/16 hole in the seal. Small sheet metal screw an a pair of vise grips an pull it out. Gotta pull the IPB inner race first.
Old 07-21-2015, 08:08 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,581 Likes on 3,828 Posts
Think there is two seals plus the quad ring on a 96 just like my 04. The quad is behind a spacer that is behind the big seal you see. Before it was used, the inner area you see leaking depended on a smooth metal to metal face sealing it. The big seal seals on that OD of spacer but the sleeve is over the seration. Behind the serration is the quad that now seals the face of the spacer. If it leaks, it lets oil run out and the out V in serration. I would look for any chips behind that small seal that Soft pointed out and make sure input-shaft fills snug with no up and down shake. There is two sets of small needle bearings behind it. My first attachment is the main drive gear looking out, then the input shaft and one of the two bearings.
This may help since it's difficult to understand even when I read what I wrote? HA
http://partsfinder.onlinemicrofiche....ING%20ASSEMBLY
Old 07-22-2015, 06:14 PM
prplglide's Avatar
prplglide
Thanks for the replies, guys!
Based upon the link you've provided, RS, that would be #19 in the exploded diagram.
Hmm.... I did notice a fair amount of metal particles (very fine) stuck to the magnet. I didn't think too much of it, until now....
Old 07-22-2015, 07:17 PM
soft 02's Avatar
soft 02
soft 02 is offline
If your up for it, rebuilding the tranny would cost about $150 in bearings, gaskets, and seals. I know its not the same but I have a diy tranny rebuild thread in the primary section if you want to check it out. I didn't use any special tools either. You are 80% there as far as pulling it apart.
Quick Reply: Main shaft seal
