Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch assembly- are those 16 rings aligned with each other in particular order?
Old 08-31-2015, 07:57 PM
tonemachine's Avatar
tonemachine
tonemachine is offline
Default Clutch assembly- are those 16 rings aligned with each other in particular order?
2000 electra glide classic.
Changing stator and things got a little hairy I might have unintentionally spun a couple rings a bit. I notice that each ring has at least one notch on its edge and each looks to have a black "tooth" (or 2, I forget) but there doesn't seem to be any order to these things. Is there any required alignment of these rings, besides front to rear order of the rings themselves? I guess if worse comes to worst I can put in a whOle brand new clutch, guts untampered with by me, but I'd rather not if it's not necessary.
Thanks in advance!
Old 09-01-2015, 03:53 PM
tonemachine
Not according to someone I talked to but things I've read suggest maybe they are supposed to be aligned some way. Any input from someone who knows for sure?
Old 09-02-2015, 05:35 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
This should be the same as the OEM clutch plates.
high_beam
Milwaukee Eight (M8)
14
06-29-2021 09:40 PM
spiguy
11-19-2017 05:11 PM
Lee Chewy Link
12-15-2014 08:05 PM
berndog
Shovelhead
17
10-05-2012 06:58 PM
drspencer
12-30-2011 07:30 AM
Quick Reply: Clutch assembly- are those 16 rings aligned with each other in particular order?
