Needing a clutch.
Old Dec 14, 2014 | 08:21 PM
Lee Chewy Link's Avatar
Lee Chewy Link
Stage II
Question Needing a clutch.
I have a 2003 FLHTCI (Electra glide Classic). Getting a little slip in the clutch. Adjusted the clutch with no change. Trying to find out recommendations for a new clutch? I'm also considering towing in the future so, What would be a good replacement clutch that would be suited for towing and where is the best place to get it? Look forward to some answers.
Old Dec 14, 2014 | 08:30 PM
QC's Avatar
QC
Look into Energy One, recommended by Mark@BakerDriveTrain.
https://www.google.com/url?sa=t&rct=...93poWCmh4vN0dA
Old Dec 14, 2014 | 11:10 PM
HOGILAC's Avatar
HOGILAC
Default Clutch
My shift linkage just came lose and I rode it to a safe spot while burning out the clutch...., dropped it of at shop to have a barnette clutch set installed.
Old Dec 14, 2014 | 11:20 PM
mikelikesbikes's Avatar
mikelikesbikes
Barnett Scorpion here. So pretty you hate to cover it. You will never need another clutch. I put one on at about 75K (guessing). Comes with all the springs to give it the pressure you could want. Kinda pricey at about $480 but worth every penny.
Old Dec 15, 2014 | 06:10 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
imo the stocker is fine if u use a stronger spring, after checking and replacing the discs.
Old Dec 15, 2014 | 07:23 PM
DHubbs's Avatar
DHubbs
My clutch started slipping after about 30k miles on my 2010 ultra. I installed a Barnett +1 clutch & heavy spring & Clutch Wiz. This setup worked great but after inspecting the original clutch plates I am sure I could have fixed the problem by simply replacing the clutch spring with a SE heavy spring.
Old Dec 15, 2014 | 08:05 PM
wiseguyups's Avatar
wiseguyups
I think the oem clutch is fine. I replaced mine this past spring because I was in there to put a new drive belt on. I had no clutch problems at the time but had about 120k miles on it so I replaced it and the stator.
BuckeyeUltra
Aug 16, 2023 10:21 AM
texacon
Jul 18, 2011 07:32 PM
J.Teaser
Feb 16, 2008 11:29 AM
baron3547
Oct 5, 2006 12:35 AM
Pippeis
May 27, 2006 12:36 PM
