Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Excessive
Old Sep 1, 2015 | 07:41 PM
derikj1995's Avatar
derikj1995
Stage I
Default Excessive Vibrating
Guys I'm out of options. I can't figure out why my 02 softail Standard carbureted (FXST), vibrates so much. I was wrapping it up with the clutch pulled on the interstate one night then it started. Ever since then the engine vibrates so much that the tank rattles loud against the frame on acceleration and deceleration and my highway pegs vibrate my feet off. She also shakes like a dyna at idle. My motor mounts "look" good but I'm no expert. Please help this fellow rider!
Old Sep 3, 2015 | 09:38 AM
djl's Avatar
djl
Sounds like you spun the balancer chain sprocket which is an interference press fit on the crankshaft; bad juju and a major repair if that is what happened. Another possible cause could be faulty motor mount; the softail motor is hard mounted and relies on the balancer system to reduce the transfer of motor vibration to the frame.
skloker
EVO
33
Sep 8, 2016 09:17 PM
SC-Longhair
Feb 24, 2009 07:40 AM
jhmp
Jan 2, 2008 08:32 PM
Rocket350
Sep 7, 2007 07:34 AM
JonnyD
Aug 24, 2006 03:59 PM
