Rubber-mounted
Old Feb 24, 2009 | 07:28 AM
SC-Longhair's Avatar
SC-Longhair
Default Rubber-mounted
I just thought of something. Stay back 200 ft. lol
Seriously though. We have rubber-mounted engines, right? That is supposed to keep the vibes down a bit, right?
So if the motor is rubber mounted as opposed to rigid mounted like on a softy, the motor will have some play.
So, in essence, we buying rubber-mounted motors and then slapping (true track) something on there to make it act closer to a rigid mount.
Seems silly.
Old Feb 24, 2009 | 07:33 AM
Grind's Avatar
Grind
Sort of. The True-Track limits the direction it moves. Without it, the mounts can move 360°, with the TT, the mounts can only move up/down, eliminating the side to side movement that causes the rear end to shift.
Old Feb 24, 2009 | 07:37 AM
SC-Longhair
I understand the science behind TT. I guess the setup just isn't appealing to the eye. Why not do something directly with the motor mounts themselves for a cleaner setup instead of having that hunk of stuff on the lower frame? Just thinkin out loud.
Old Feb 24, 2009 | 07:40 AM
sniper77's Avatar
sniper77
If you used solid motor mounts (like with a car when you want all the power to go to the wheels) the vibration would be so bad the engine would have to have internal balancers...i.e softail 96B
lakedrum03
Jan 2, 2016 10:23 AM
Misbehaven
Engine Mechanical Topics
Apr 1, 2015 09:27 PM
coconl
Jan 8, 2013 09:13 PM
Beemervet
EVO
11
Apr 2, 2008 08:26 AM
jhmp
Jan 2, 2008 08:32 PM
