Somebody help ! 05 deluxe twin cam problems
I have a 2005 deluxe twin cam. I hardly know anything about motorcycles but I'll try to describe this the best way I can. When I was riding my bike seemed to suddenly slip and start making awful grinding sounds even when I was not engaging the clutch. Now my bike is in my garage and when I try to start it it makes a loud knocking sound from the gear side of the engine and it won't start at all. I took the circle plate on the side of it that is held on by 5 hex screws to expose what looks like flywheel maybe? Either way I noticed I have oil all thru there.. Is that normal or what's going on ? Hopefully someone can help me I'm a complete noob when it comes to this. Thanks I posted a pic of what I'm looking at to better explain
I know but I need to find where the problem is coming from because I don't have a whole lot of money to work with. Is it normal for oil to be all loose in there?
Yes, the big chrome cover.
Drain the primary lube first, there is a plug on the bottom of the primary.
The plug is item 20 in the illustration.
http://www.granitestateharleystore.c...RY|~HOUSING\BN
Be gentle when removing the cover, you might be able to save the gasket.
Be prepared for sticker shock if you need to buy a new primary cover gasket...
